I set up an automation to create a subtask when any new issue is created. But, it keeps showing an error that one of a required field makes it fail. It's our "Tag" field. So, I took out "Tag" field from subtask screen. But, the automation still fails. How can I resolve this problem?
I'm attaching the automation setting just in case.
Welcome to the Community!
Screens do not have anything to say about fields being mandatory. You have two routes to make this work - either make the field optional in the field configuration (not the screen), or have the automation set your "tag" field.
Hi Kim,
Can you please share the step, how you fix this?
Amit - When you automate to create sub-task, click "Add Field" and select "Tag" Field and give value or alternate option is given by clicking the "..." next to field and select "Copy from Issue"
Hope this explains!
I also have the same issue. But im not using Tags in my screen. how can i solve it otherwise?
Maroof, "Tag" is the custom field name in the above example. When you create sub-task with automation, you need to make sure the required field has some value. In above example, I have explained to copy the value of "Tag" field from parent issue into sub-task. That will solve the issue as the required field has value what parent issue has.
Hope this helps to clear your problem.
Here you can replace "Tag" field with your field...
