I hava a Issue Type calles "Raum"- In the workflow I added the transition from the Status "Bestandesaufnahme" to the same Status "Bestandesaufnahme" with a Screen. I want to create a Subtask based on the information from the transition screen. How do I do that?
I have created the following Automation:
And I get the following Error:
What is wrong with the automation?
Hi Tiziana,
Please go to "Then" tab and check if Summary is copied from trigger issue:
Hope this helps.
@Tiziana Pisenti - Follow the below steps in order to create the automation rule as per your requirement
Configure the trigger:
Add a condition (optional):
Add the action:
Copy from trigger issue
. This will ensure the sub-task is created under the transitioning issue.Create sub-task based on {{issue.fields.customfield_XXXXX}}
(replace customfield_XXXXX
with the ID of the custom field from your transition screen).Publish the rule:
Let me know if this helps!
@Bandarupalli Sai Thank you for your help. How exaclty do I use smart values to reference from the transition? I set the fields like this, but it doesn't work
@Tiziana Pisenti - You have to select the sub-task issue type from the issue type drop down or use/select the "create sub-task" option under action as shown in the below screenshots
FYI - You can copy any system or custom field values from parent to sub-task but in order to do that fields should be available on both parent and sub-task screens.
Hope this helps now!
@Bandarupalli Sai Thanky you. The fields I want in the subtask are not in the parent case. They are in the transition from the parent case and with the transition i want to create the subtask.
If the fields are on the transition screen, you can copy the field values from parent to sub-task. However, the fields will be updated while transitioning the issue.
@Tiziana Pisenti - Can you check and ensure that the Summary
field is not hidden or restricted in the respective issue type Field Configuration?
