You will need to use a plugin such as ScriptRunner to accomplish this. Since the approval is already in a workflow transition you can add it as a post function. The post function can evaluate the field and then auto generate the issue using ScriptRunner.
Hi Brant,
Can you please help on the code.
I have one custom field called " change type" that is single select drop-down list with the value options "installation","configuration changes","patching","Deployment","infrastructure",golden configuration changes". and other custom field called " Change step" that is " text Field" means whenver a Change step field value is updated, automatically need to create a ticket in jira, which means whenver a ticket with change type = golden configuration changes or " golden configuration changes is approved, trigger an auto creation of jira ticket
