Hi!
I have a problem with my automation. I want to assign issues to specific user after creating them. I chose exactly the same options as here: https://www.atlassian.com/software/jira/automation-template-library/auto-assign and the automation doesn't work. I checked the logs after creating a new issue and the automation has failed. The reason is that the issue didn't meet the condition. What might have gone wrong?
Hi @Natalia Chojnacka -- Welcome to the Atlassian Community!
The issue created trigger may have timing issues, where the rule fires before the issue data is fully available. This can lead to rule conditions not matching.
The work-around for this is to add a Re-fetch action immediately after your trigger, and before your condition. This will reload the data and slow the rule down prior to the conditions.
Hi!
Adding a re-fetch action worked perfectly! Thank you for your help.
Natalia
Hi @Bill Sheboy
So, I have an automation which triggers when an Issue is Created.
Within Jira Project A, the Default Assignee is set to the Project Lead.
Within Jira Project B, the Default Assignee is set to Unassigned.
After the automation is triggered, the very first condition is an If/else block which checks for -- among other things -- if the "Assignee is empty".
For new tickets in Project A (where the issue is assigned by default to the Project Lead), apparently the auto-assignment was taking a long time. As a result, my If condition was passing (because the assignment had not yet occurred).
So, I added a step to re-fetch issue data. However, the auto-assignment was still taking too long. As a result, my If condition was still passing (because the assignment had not yet occurred).
So, I added another re-fetch data (for a total of 2). Still that didn't work.
So, I added another re-fetch data (for a total of 3). Still that didn't work.
So, I added another re-fetch data (for a total of 4). Still that didn't work..
Am I doing something wrong? Is there a better way to wait for the auto assignment to work?
Hi, @Doug Levitt
First thing: wow, that surprises me it takes that long! I would submit a defect for that one to Atlassian.
Is this a global/multi-project or a project-scope rule?
As for a work-around, there is no available smart value/action to set a user field to the Project Lead yet. But you could disable the automatic set to the Project Lead, and then use your rule to call the REST API with a webrequest to get the user and set from there: https://docs.atlassian.com/software/jira/docs/api/REST/1000.824.0/#api/2/project-getProject
So, as it happens the re-fetch data operation was working properly.
What wasn't working? Well, the Automation was providing misleading information in the audit log for the If/Else block (see: https://jira.atlassian.com/browse/JSWCLOUD-23209).
Typically, I use Slack Messages (in my Automations) to facilitate debugging and troubleshooting. For whatever reason, I hadn't done that and relied on that inaccurate information (in the audit log) for deducing what was happening. I guess that was a mistake.
Doug
Thanks! That one is a troubling and curious behavior. Lots of people, including me, rely on the audit log for tracking rule behavior...and seeing this is gonna make me check my rules more closely.
I added a comment to the ticket indicating the following:
Since this is an "Audit Log", I would suggest that the priority be raised. As any of your customers operating in a regulated environment would need to abandon this mechanism entirely. I would argue that this is at least Major and possibly Critical (at least this has applied to any software I have built where auditing is known to be incorrect).
Automation looks fine. Did issue was unassigned during creation?
Can you share screenshot from audit log?
Seba
yes, my issue was unassigned during creation. Audit log:
