Automation for JIRA Plugin issue
SHANAVASH MOHAMED
Hi Team,
I saw some of the videos there i saw in the "Automation for JIRA plugin" Schedule and new action item inside "Send Excel" option.
I installed "Automation for JIRA plugin" in my local machine  but i am unable to find the "send Excel" option.
I have attached the Video reference link and My Screenshot as well, Please do the needful for us.
video Reference : https://youtu.be/vdDAoCTdJNc
Screenshot
screencapture-localhost-8085-secure-AutomationGlobalAdminAction-default-jspa-2020-08-14-12_01_59.png
Ste Wright
Hi @SHANAVASH MOHAMED
This is another app, which extends the functionality of Automation for Jira and Better Excel Exporter for Jira
A link to the app is in the YouTube video description - see Better Excel Automation for Jira
Also note from the Marketplace description:
Better Excel Automation allows generating, exporting and emailing Excel spreadsheets from Jira issues, by integrating Better Excel Exporter with Automation Lite.
Note: both those apps must be installed before this can be enabled!
Ste
SHANAVASH MOHAMED
Thanks @Ste Wright for quick response.
I installed both plugin in my local but send excel option isn't showing.
Shajan
Levente Szabo _Midori_
@SHANAVASH MOHAMED,
The order in which you install these apps matters due to the dependencies between them.
Please make sure you follow (reinstall) the right order outlined in the app's documentation: https://www.midori-global.com/products/better-excel-automation-for-jira/server/installation
If you still can't see the automation action, please open a ticket and we can look into it for you.
SHANAVASH MOHAMED
Its working fine for me. Thanks a lot.
and one more problem i am facing when i got mail that xlsx format isn't opening it showing resource not found error. I have attached the screenshot for your reference, PFA
shajan
Most probably your Excel export template has been renamed or removed.
Please open a ticket for the technical support team, so they can look into it for you.
