Hello
I in our workflow we have the status "Wait". When we transition to the status we set a "Wait until" date.
Once that date's been reached the automation rule executes and notifies the assignee via e-mail about the waiting period being over.
The "Wait" status can be reached from various other statuses but can always only go back to the previous one and itself.
Now we want the issue to automatically transition back to the status it came from,
(Like, if it comes from "Planning" it can only go back there.)
I already tried it with smart values from the Advanced fields documentation but that didn't work.
Specifically I tried using the value below. But it always gives me an error in the audit log that the transition needs a numerical status id.
{{#changelog.status}}{{from}}{{/}}
Is there any other way to solve this?
Thanks in advance.
Hi Sebastian,
Yes we don't really support this very well yet (see https://codebarrel.atlassian.net/browse/AUT-47).
For now the best option would be to record the previous status id in a custom field as @Christopher Jaksch mentioned.
You could use a rule like this:
Then you could transition to {{issue.Previous status}} using the 'Transition action'.
We'll hopefully make this easier in future, but we've got quite a few higher priority items in our backlog currently.
Andreas
How was this accomplished? I'm not sure what "transition action" means. Where do I place "{{issue.Previous status}}"?
Hi Derk
How did you do:
I can't figured it out yet :-(
Dear @Derek Mart - How can I specify {{issue.Previous status}} in the Transition Action? - All I get is copy or the statuses available but no free expression field.
Jan
Can anyone think of why I would get a 5-digit code for {{fieldChange.from}} for status instead of its actual two-digit code?
@Peter Reiser @Derek Mart @Jan Stähle I also see the Transaction Action but don't know where to specify {{issue.Previous status}}. Kindly advise possibly with a screenshot. Thanks!
Figured it out. Never mind. Lol.
For anyone who's losing time figuring it out, paste {{issue.Previous status}} into the dropdown field for the statuses. It then gets recognised as a smart value. Yes, it's not intuitive enough and took some trial and error to get it.
I don't understand this.
Can u help me?
I have an issue with this approach as well, when I want to save previous status on transition, the field doesn't get updated.
What should be the edit issue smart value in this case?
Ok, i found the problem.
For some reason Issue Transitioned trigger doesn't work with this - you'll have to use Field Changed for Status field - then everything works great.
I followed the steps as suggested but it doesn't seem to work for me.
My goal is, for every tickets with a status of "Cancelled", if anyone creates a comment on the ticket, the ticket will automatically reopen and transition to the previous status it was from.
Can you help me determine what I'm doing wrong?
ng?
@Boriz Agustin Can you please share your audit log for this automation?
Also please try this: Remove Edit issue fields node you have here, and create a separate automation to save the previous status into custom field. Something like this:
And then just use your current automation to change and transition the issue, just without saving the previous status bit in the same automation.
Hello @Bartosz Mazurek thank you for the assist. I tried what you suggested but still it did not work.
I have created a separate rule that defines the value of Previous status through Project automation. See below:
And modified the original Automation:
Same issue occurs, the status still remains the same.
@Boriz Agustin It looks like the issue is that automation cannot resolve the status its supposed to transition the issue from your custom field. What did you setup your custom Previous Status field as?
I have it set as Text Field (single line), can you check/confirm this?
@Boriz Agustin Can you show how does your previous status field looks like? I mean what exactly gets written there.
@Boriz Agustin I meant the actual data that gets stored in the field. You can for example showcase the Previous Status on issue screen, so we can see actually what gets written there for each issue.
@Bartosz Mazurek Oh OK, sorry about that. The automation seems to blank out the field. I tested this by putting an initial value to the "Previous Status" field during create.
@Boriz Agustin I think if you fix that to make sure that the field always contains correct status ID, whole thing should work correctly.
Hi @Bartosz Mazurek , yeah, that's the exact problem I'm having. I'm using "Allow all statuses to transition to this one" on the Cancelled status so setting the value on post-function is not really an option. Any ideas on what else to check on why it doesn't get populated?
@Boriz Agustin Try using the automation for saving previous status as I shared in one of previous screenshots, where it gets triggered on every transition by using When: Value changes for: Status. I think that should work correctly.
Thank you @Bartosz Mazurek , I believe that will work but the triggers available for me is limited and does not allow to target specific field change.
P.S. I was able to make this work using the {{#changelog.status}}{{from}}{{/}} and {{issue.Previous status}}
Thanks all! I was able to get this to work by using "Re-fetch issue data" between the When clause and the Transition.
Hi @spe,
as a workaround you could define a new custom field "previous status" where you enter the "string" of previous status automatically via post function.
You could use this information for your automatic rule to go back from "wait" to the previous status.
Hope that helps
Best wishes
Chris
STAGIL
Just jumping in on this as I have had similar issues as many on this thread!
So first off "{{fieldChange.from}}" didn't work for me. Like many others I found that "{{#changelog.status}}{{fromString}}{{/}}" was working to set the Previous Status field to what appears to be the name of the Status.
However it appears that it's setting it to a "Status - Status ID" value which when you attempt to use it in the other rule Automation doesn't like.
So I ended up using "{{#changelog.Status}}{{from}}{{/}}".
My rules that are working for peoples context:
Hi Community,
Just been reading through this chain of threads, and wondering how this is possible when the initial poster said: "..The "Wait" status can be reached from various other statuses but can always only go back to the previous one and itself..."
Unless there is a transition back to the previous state in the workflow, how is this possible?
They never shared a workflow so I guess we can assume one of the following:
From working on other similar automation rules it will error if it's unable to find/resolve the target destination status. Either because there isn't a transition or the "previous status" field has become stale/outdated.
Where I've implemented similar there a few sections of the workflow where I didn't technically want it to transition to the previous status, so I put in workflow post functions (or automation rules) to set the previous status field to the desired Status ID I would want it returned to.
Post functions sounds like a great idea, I'll look into that.
Hi, I hope this helps someone! I saw a lot of people doing multiple rules. I have managed to do it in a single rule! It works as expected.
Hi all,
Can maybe someone provide a screenshot how the automation worked at your end, which trigger do you use?
My goal similar to yours: Move an Issue from "Blocked" Status to the previous one.
Thanks and Best,
Xheneta
Hey @Xheneta G. Hyseni ,
this is what works for me:
Here I am saving the previous status to a custom field:
And here, in separate automation, I am changing the status to a previous one. Just the transition issue is necessary to move it, all the remaining steps are for my case when I want this to happen.
Hello @spe
If documentation is correct, it should work.
I would advise you to raise request to Automation support, because i didnt see many codebarrel guys on community :)
And you can try some workarounds, like create branched rule, that will checks prevous status
and do direct transition based on status.
Hello @Mark Markov
I tried that, too. Unfortunately it doesn't work. In the audit log it always says that the issue doesn't match the compare condition...
I'll try the Automation support then.
Thanks.
{{issue.Previous status}} did not work for me. I'm getting an error when using the smart value as seen below. Can you please advise what I'm doing wrong?
Hi @Tristan , can you show the details? Because I have tried your suggestion but it didn't work and I am kinda desperate.
Thanx
