Automation for Jira trial license
Vinnie Chhabra
Hi Atlassian community
   I read that Automation for Jira is free in Jira Datacenter.
We are still running Jira Server and I'm trying to find if there's still a 30 day trial license to test the add on.    DOes anyone know where I could find the Automation for Jira trial license for Jira Server?
Vinnie Chhabra
Silver Noman
February 7, 2024
Hi Everyone!
Is it still possible to generate trial license?
I'm getting error (Oops! Looks like something out the back is broken.) for several days when I push Try in Marketplace.
Florian Bonniec
Hi @Vinnie Chhabra
You can use a DC trial license to test automation for Jira on a server instance.
To get a trial license, go to https://my.atlassian.com/product and generate a new trial license,.select Automation for Jira Data Center in the list then fill in the requested information. It's the same process as requesting a trial license for Jira Software for instance.
Regards
Vinnie Chhabra
Thanks Florian.    Do you know where I get my 16 digit Server-ID?
Vinnie
Vinnie Chhabra
FLorian, I was able to find it under System INfo.  Thanks so much for the help
Alex Koxaras -Relational-
Hi @Vinnie Chhabra
Get a trial license for Data Center. I think that you wouldn't have a problem. And yes, the DC license comes with 30days evaluation
https://marketplace.atlassian.com/apps/1215460/automation-for-jira?tab=overview&hosting=datacenter
But you can try the lite version which is for server
https://marketplace.atlassian.com/apps/1211836/automation-for-jira-server-lite?tab=overview&hosting=server
Vinnie Chhabra
Thanks Alex!
Vinnie
