Automation for Spillover Subtasks
siva.vemula February 3, 2025
Hi There,
I Subtasks on the stories .
I am looking for a Automation Rule which track Stories that spill over into the next Sprint, ensuring that any Sub-task that isn't completed gets marked as Spillover = Yes. when the sprint is closed.
Vishal Biyani
February 3, 2025
@siva.vemula
You can try below automation rule
Hi @Vishal Biyani  Thank you so much. If the subtasks is NOT DONE, the issue filed Spillover should be updated as YES and if the Subtask is DONE the issue filed Spillover should be updated as NO.
Can you review and correct
Vishal Biyani
February 3, 2025
in that case in Issue matches JQL use issuetype in subTaskIssueTypes()
Then add another if Issue matches JQL condition:
check statusCategory = Done
then edit issue fields to set Spilled Over = No
check statusCategory != Done
edit issue fields to set Spilled Over = Yes
@Vishal Biyani  Can you help with the screenshot please
Vishal Biyani
February 3, 2025
@siva.vemula
Can you make the change and share the screen shot of what you have done?
if you hit an issue, I will be happy to help. However, for your own learning, I encourage you to try this out yourself first
image.pngKindly validate
Vishal Biyani
February 3, 2025
I think what you can do instead of having 3 if condition,
in 1st condition, use issuetype in subTaskIssueTypes() and statusCategory = Done
then edit issue
in 2nd condition, use issuetype in subTaskIssueTypes() and statusCategory != Done
then edit issue
that will ensure that both ifs are evaluated correctly.
Like siva.vemula likes this
I have tried the above query but for subtasks not done its getting updated as YES. But for subtasks with are done Spillover filed is not getting updated.
Kindly review and suggest
Vishal Biyani
February 4, 2025
can you share the log of your automation execution
siva.vemula February 4, 2025
here it is
Vishal Biyani
February 4, 2025
2nd JQL condition shows the issues are not matching Done criteria. Looks like all the subtasks are matching not Done criteria.
Can you check if there are any sub tasks from above list that were in Done statusCategory?
yes. There are subtasks in Done statusCategory.
siva.vemula February 12, 2025
Thank you . This works
siva.vemula February 14, 2025
hi @Vishal Biyani
This automation of updating spillover field is working for subtask which are DONE , its not getting updated for Subtask which are not done. Could you please assit
Vishal Biyani
February 14, 2025
I think what you can do is, click on Add Component
Add same Branch for Issues in sprint
move the 2nd if and edit condition, in that branch.
This should work in my opinion
