I have one field for the number of volunteers the event can have (let's say 1-5). Another field for different groups that are going to attend (this is a multiple select field with the group names). Is there a way to have a "FULL" field that flips to full if the number in field 1 matches the number of groups selected in field 2? So for example we can have 3 volunteers, once 3 groups are selected the 3rd field would flip to FULL.
Next level would be if it was less than 3 to have the field say SPACE AVAILABLE, and if over 3 were selected it would say OVER CAPACITY
Hi @Rachel Young and welcome to the community!
Yes - You could use automation to accomplish this:
Note - For illustration purposes I'm calling the fields:
Hi @Mark Segall
Thank you so much for your response! The only problem is that my "Attending" field is a multiple select field with group names. Is there a way to automatically push that info into a separate numeric field?
Ahh - Apologies I missed that. You shouldn't need the extra field. You could tweak the conditions like this:
