Automation for diff between due date and target end date
Anuradha Yadav September 5, 2024
I am doing a automation which says as below:
If a target end date is greater than due date at the epic+ level, report slippage (adding label)
Tried all below values:
""{{now.plusDays(issue.duedate.diff(issue.customfield_11629).businessDays)}}""
{{issue.”"Due Date".diff(issue.customField_11629).days.abs}} >= 30
but it says error if condition not matching. please see the snips added.
Anu
Duc Thang TRAN
September 5, 2024
Hello @Anuradha Yadav
this function {{now.plusDays(issue.duedate.diff(issue.customfield_11629).businessDays)}} will return a number field, not a true/false value.
If you want using condition true / false , you can use isAfter or is Before  for ex: {{now.isAfter(issue.created)}}
I suggest that you can compare one smart value to another smart value date, or compare one smart value to a field value, ex:
{{issue.Due Date.diff(issue.customField_11629).days.abs}} greater than 29
Hi @Duc Thang TRAN ,
as said I just want to -
If a target end date is greater than due date i want to  report slippage (adding label)
So If diff between 2 given dates is more then or equal to 30days I want to add label. Could you please help how to do it?
Anuradha Yadav September 9, 2024
Hi @Duc Thang TRAN  could you please check and help this is bit urgent for our team
