×Example:
Issue type "A" has a field to input the "Company Name" in text.
When issue type "B" is created and the text in the field "Company Name" is the same as in Issue type "A", I want to be able to automate the linking of both issues based off the same text in "Company Name" when Issue type "B" is created.
Please help.
Thanks.
If I understand correctly, you want to associate each issue with a company (through the "Company Name" field) and you want to link the issues that are associated with the same company. If so, then the solution you're thinking about may not be the most intuitive.
Problems that I see:
Alternatives:
@Aron Gombas _Midori_
Problem #1 answer: 20 issues will never be associated with the company.
The hierarchy I'm working with is:
Client (Standard Issue Type) > Product Name (Epic) > Project Stage (Task) > Tasks (Sub-tasks)
For each client, there are at most 5 products at a time.
The product is what I want to associate with the client.
Problem #2 answer: I believe if we spot these typos during our weekly meeting, they will be fixed.
Alternatives:
1. What is an insight object?
2. Can you elaborate on this please
3. Please elaborate too
Answers (although you could find these with 2 min of Googling, to be honest):
