Automation not triggered when permission changes
Onur Cevik
Hey,
I have an automation rule that assigns an issue to its reporter when it's moved to another column on the board. It has worked yet.
Yesterday I changed the permission screen so that only the creator, assignee and administrator can see their own issues. Since yesterday I get an error message saying that the automation has failed because the actor does not have permission to see the issue. Can anyone help me? How do I solve the problem in order to get my desired settings to assign a certain person as assignee and that the creator can only see it´s own issues (the assigned person and administrator have to see all issues)? Screenshots below.Bildschirmfoto 2024-01-23 um 09.07.06.pngBildschirmfoto 2024-01-23 um 09.08.29.pngBildschirmfoto 2024-01-23 um 09.09.06.png
Jeroen Poismans
Hi!
Seems so that by changing the permissions, you also changed them for the actor of your rule.
The actor should have permission to view the issue (Browse project) + should also be able to assign issues (Assign issue permission) on project level.
Who is the actor of your rule? You can find this in the Rule details. There is a built-in actor available (Automation for Jira) which should solve most of your permission related issues in rules.
Regards!
Onur Cevik
Thanks. I try to solve it by adding a filter.
project = SYS AND (creator = currentUser() OR assignee = currentUser() OR projectsWhereUserHasRole("Administrators") = currentUser())
ORDER BY Rank ASC
Do you know why it does not work?
Onur Cevik
projectsWhereUserHasRole... does not work because the field is not included in my mask. But is there a way to assign certain persons to currentUser?
