How to set automation rule that Linked issues start date (and accordingly due date) would be changed according to predecessors (i.e. Blocked By issues).
I did a try but still not working
Hi @Mohamed Fouad ,
Can you give more details about what you tried?
This other post may also be helpful: https://community.atlassian.com/t5/Advanced-Roadmaps-questions/Dependencies-change-Start-and-Due-date-based-on-blocked-issue/qaq-p/1943998
Thanks a lot @Carlos Garcia Navarro that was helpful, I tried to run through same automation logic and will see outcome
