Automation of notification for Tasks
Rikhard June 21, 2022
Hi there, I am creating Gannt Chart with Tasks, but I need to have an automat notification by email before each task specific en date, for example 3 days before I want to get notification that You have left only 5 days before You Task end date. How can I do it?
Thank You!!!
Fabian Lim
Hi @Rikhard
You can use the following to get it working if you have a specific end date custom field.
Trigger is a scheduled trigger based on a jql and then send a notification.
Link: https://youtu.be/ccWTIgdnQqE
Good luck
Hi, thanks for Quick response, to be honest I am not so good in jql, so don't now how write the correct one. But will try to find, thanks for the help
