Context:
I have several projects in Jira, and one of those project which I use to mantain mandatory documentation about the other projects.
project documentation --> project.id = AAA
Several projects with diferent projects id, for example {project.id:001,.... project.id:050}, and differents projects lead (project.lead)
Problem:
What I want to do is to create a rule triggered manually where I set an array of projects id and the rule creates a package of issues in project AAA, each pack of issues relates to the each project.id and its project.lead.
Is this possible?
Thank you very much in advance!
Hi @Gema Ruiz
If I understand your question, your scenario is:
Given I have a Jira project with documentation, and that project has a custom field containing a list of other projects
When I manually trigger an automation rule
Then that rule will create several issues in the projects specified by the list of other projects
That seems possible, although I believe you would need to use a web request to call the REST API to create the issues. The built-in Create Issue action cannot take a parameter/field to select the target project.
Here is a how-to article for calling a REST API function from a rule:
And here is the reference for the REST API functions for issues. There is a single Create Issue and a Bulk Create Issues to consider.
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-group-issues
