Automation rule - Project default setting
Somnath Raveenthiran
Can someone guide me on how to change the legacy automation rule from project default to our name in Jira service management?
John Funk
Hi Somnath,
Is there no name at all that comes up when you try to convert it? I would accept whatever name you can to convert it and then change it after that.
Thanks John figured it out how to change it
Like John Funk likes this
John Funk
What was the solution?
Just typed our internal support team name in configuration area and It took as Project default for all the rules which we had.
