Automation rule for mandatory field
ibm_kustagi_mercedes-benz_com
PI Test.jpgHi,
  I have created automation rule  for one custom field when issue is created if custom field is empty then it should show as None. Please let me know if my logic is correct as while creating ticket I am not able to achieve it.
Suma
3 accepted
Pedro Olmo
Hello @ibm_kustagi_mercedes-benz_com ,
Can you include screenshot with configuration single choice type. customfield values?
Regards
Yogesh Mude
July 21, 2025
@ibm_kustagi_mercedes-benz_com  Does this None is the option added in custom field? and what type of custom field it is? assuming ist not added, in this case you can set the None option using the automation rule as its not present.
@Yogesh Mude  yes none value exists and custom field is single choice type.
Yogesh Mude
July 21, 2025
okay, great, if the None value/option exists then you just need to select the None option in the Edit work item action.
for an exampleL: as shown in the below, assume Issue type is your custom field.
Like Maria Rusnakova likes this
Nikola Perisic
Please include the screenshot of your automation rule, it wasn't attached in the original post.
@Nikola Perisic updated the details
ENTERPRISE
