Hi Team,
I have created a "Issue Security Schemes" with 2 levels -> Level 1 and Level 2
I have made Level 2 as default.
Security schemes is working as expected with permission schemes and everything as expected
but,
Creating a automation rule for setting the security level to Level 1 when the component is updated to certain value is not working as expected.
My automation rule:
Not sure what I am missing. Automation rule is not working.
Note: I have gave the permission for "Automation for Jira"
Please help!
Does the rule trigger? And if so, what does it say in the Audit log of the rule?
Can you make sure the "Security Level" field is actually on your Edit screen (for that issue type)?
Jira can only edit fields that are on the screens that you use.
