Automation to move a cloned issue from one epic to another in a different Jira project
Mateja Leskovec
Hello everyone,
I'd like to understand if it's possible to set the following automation:
Each team working on a product has their own Jira project. Their work is tracked in different epics under one initiative per product. As the products are kicked off, the epics are created - meaning that each project has it's unique initiative and respective epics.
At one point we'd need to clone a ticket from Project A to Project B, but also track it under the epic of Project B.
Does the automation support this?
Thank you!
Trudy Claspill
Hello @Mateja Leskovec
Are these Company Managed projects?
Automation has a Clone issue action that would allow you to specify another project as the destination. In that action you can also set the fields in the newly created issue, and that would include setting the Parent of the new issue to match the source issue
This works only between Company Managed projects.
Mateja Leskovec
Hello Trudy,
we would need also need the Parent of the newly created issue to change to a different epic under the same initiative.
So the completion of the original issue in Project A and under Epic C would created a clone of X in the Project B and under Epic D, but both housed under the Initiative X.
Trudy Claspill
The Clone action allows you to set the Parent field, which is how you identify the parent/Epic for the newly created issue. Here is a simple example where you know the explicit issue key of the Epic.
The next thing you have to determine is how you will know what Epic to specify. Do all the cloned issues go to the same Epic, every time? Or is there some logic you need to execute to determine the Epic that will be the parent of a particular clone?
Mateja Leskovec
Hello Trudy,
every time is a different epic under the same initiative, so the automation would have to figure that out while cloning the issue.
Trudy Claspill
If it is going to be a different Epic each time you are going to have to provide some logic for how that Epic would be determined.
If you were doing this task manually how would you determine the destination Epic?
Alternately you could use a Manually triggered automation rule where your user would manually trigger the rule to clone the issue. With a manually triggered rule you can prompt the user to enter the issue key for the destination Epic and then use that dynamic input within the automation rule to set the parent of the newly created issue.
Luka Hummel - codefortynine
Hi @Mateja Leskovec
If you are willing to try a third-party app, you can try our Deep Clone for Jira.
Deep Clone can keep the original Parent Link when cloning issues to other projects.
Mateja Leskovec
Hello Luka, we would want this to be an automated process, not a manual one.
Hi @Mateja Leskovec
That's not a problem, you can use Deep Clone together with Jira Automations and use a normal Jira Automation trigger to start a Deep Clone. You can read more on that here.
You then can also use the Field Editor feature, which allows you to set a new Parent for the cloned issue(s). Furthermore, you even can use Jira Expressions to set a dynamic parent.
