Is there away to get the creation date of a linked issue ticket put into the description footer of the linked issue from the parent issue?
Been using Automation for Jira and not sure its possible. I know the linked issue is on the issue ticket. I got requested to add a creation date of the linked issue some where on the ticket so they have the information available.
I know some integration tools are able to put data in the description footer and wondering if we are able to do the same?
Hi @A A Ron Geister [Trundl] -- Welcome to the Atlassian Community!
You could add the key and creation date of any linked issues to the end of the description field with automation. However, what problem are you trying to solve by doing this?
Some notes before trying this rule:
Bill,
Sorry for not giving enough information. I am looking to put the creation date of the linked issue (parent issue) into the description footer so that the person reading the ticket can see when the originally issue was created.
This is for a RMA type issue that is being created by automation to fullfil a part order. I would give IF statements so it only created this for specific issues or within the current automation if I am able to do so.
I wasn't sure how to add description footers like some add-ons or integration sync tools do.
Thanks for the additional information, Aaron.
I am a bit unclear on what you mean by "description footer". To add the information you note as text to the description, a simple example rule is below, assuming the parent is an Epic and this is a company-managed project:
{{issue.description}}
Parent {{lookupIssues.key}} created: {{lookupIssues.created.fullDateTime}}
If you are instead doing this for a team-managed project, please change the condition to check "parent" and the lookup issues JQL to key = {{triggerIssue.parent}}
Bill,
What I mean by the Description footer is at the end of the description field is adding notes there. See bottom of this reply!
So I can use a smart value to look up issue and put the information into the description field & or maybe another field like environment?
This would be the description footer!
Yes, you may add the parent info to the description as I did in my example. To add that same info in another field, just edit it as well.
Bill,
Thanks so much for the assistance.
Glad to try to help!
