Barcode solution for Insight (besides ScanStar)
Alvin
Is there an easy barcoding solution you can use with Insights? Need a simple way to scan barcodes and have it entered into Insight.
Evelyn Kroll December 12, 2024
To easily integrate barcode scanning into Insights, consider using Dynamsoft barcode reader, a Bluetooth or USB scanner, or a browser extension. Ensure compatibility with your barcode format, define how scanned data will be mapped to Insights fields, and utilize automation tools for efficiency. Prioritize security measures for sensitive data.
Fabian Lim
Hi @Alvin
You may want to try the following plugin: https://marketplace.atlassian.com/apps/1219263/scanstar-for-insight-and-jira?hosting=cloud&tab=overview
Uses a barcode to update insight object schemas.
Alvin
Looking for alternatives to scanstar.
Like Carmen Nadeau likes this
