Hi all.
I am fairly new and testing JIRA and Confluence. When starting I was given a Product by Atlassian = team-1603...
I somehow managed to have another product = Terminal3 but can't remember how and where I did this.
I learned that this has nothing to do with my projects which are underneath the products.
Can anyone help?
Thx
Matt
I assume you need to create a Team Project in Jira? When you click PROJECTS on the menu bar, do you see CREATE PROJECT at the very bottom?
Thx.
I do have the button to create projects. That is not really my problem. I can create as many projects as i want.
The thing is, that new projects are either under „team-1603…“ or t“erminal 3“ (see screenshot below).
And I don’t know how I did manage to create these 2 JIRA Software products mentioned??? And where and if I can update or delete them???
Thx and cheers
Matt
OH, you have several instances of Jira in the cloud. I don't use the Cloud version, but I did find this:
Maybe that will help?
