Behaviour stops working for resolution values
Aditya Sastry
July 28, 2022
My requirement is that I want to show all the resolution values if the user is project admin but doesn't want to show "Fixed" if the user is into some other project role. I have written a behaviour which works until a point and then all of a sudden stops working. This code is added as an initializer.
This code works until I add the if-else clause and then it just stops working even if the clause are removed.
import static com.atlassian.jira.issue.IssueFieldConstants.RESOLUTION
import com.atlassian.jira.security.roles.ProjectRoleManager
def userUtil = ComponentAccessor.getUserUtil()
def currentUser = ComponentAccessor.JiraAuthenticationContext.getLoggedInUser()
def projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager)
def remoteUsersRoles = projectRoleManager.getProjectRoles(currentUser, issueContext.projectObject)*.name
def constantsManager = ComponentAccessor.getConstantsManager()
log.info(remoteUsersRoles)
if (!("Administrators" in remoteUsersRoles) ) {
def removeResolutions = constantsManager.getResolutions().findAll { it.name in ["Fixed"] }
def allowedResolutions = constantsManager.getResolutions().findAll { it.name  }
allowedResolutions=allowedResolutions-removeResolutions
getFieldById(RESOLUTION).setFieldOptions(allowedResolutions)
Error Log below -
at Script1.run(Script1.groovy:14)
java.lang.NullPointerException: Cannot get property 'name' on null object
2022-07-28 16:33:09,478 http-nio-8080-exec-36 ERROR asastry_admin 993x53804326x1 6u87vr 172.21.22.242,192.168.0.33 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] Script function failed on issue: issue: SB-16037, user: asastry_admin, fieldId: resolution, file: <inline script>
2022-07-28 16:33:09,476 http-nio-8080-exec-36 ERROR asastry_admin 993x53804326x1 6u87vr 172.21.22.242,192.168.0.33 /rest/scriptrunner/behaviours/latest/runvalidator.json [c.o.jira.behaviours.BehaviourManagerImpl] *************************************************************************************
2022-07-28 16:33:09,435 http-nio-8080-exec-63 ERROR asastry_admin 993x53804325x1 6u87vr 172.21.22.242,192.168.0.33 /rest/scriptrunner/behaviours/latest/validators.json [c.o.jira.behaviours.BehaviourManagerImpl] Script function failed on issue: issue: SB-16037, user: asastry_admin, fieldId: __init__, file: <inline script>
2022-07-28 16:33:09,434 http-nio-8080-exec-63 ERROR asastry_admin 993x53804325x1 6u87vr 172.21.22.242,192.168.0.33 /rest/scriptrunner/behaviours/latest/validators.json [c.o.jira.behaviours.BehaviourManagerImpl] *************************************************************************************
at java.lang.Thread.run(Thread.java:748)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
... 24 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 26 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 4 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 3 filtered
at com.atlassian.jwt.internal.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:32)
... 9 filtered
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilter(CustomerContextSettingFilter.java:121)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.doFilterImpl(CustomerContextSettingFilter.java:130)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.outOfCustomerContext(CustomerContextSettingFilter.java:174)
at com.atlassian.servicedesk.internal.utils.context.CustomerContextServiceImpl.runOutOfCustomerContext(CustomerContextServiceImpl.java:47)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.runOutOfContext(ReentrantThreadLocalBasedCodeContext.java:90)
at com.atlassian.servicedesk.internal.api.util.context.ReentrantThreadLocalBasedCodeContext.rteInvoke(ReentrantThreadLocalBasedCodeContext.java:137)
at com.atlassian.servicedesk.internal.web.CustomerContextSettingFilter.lambda$invokeFilterChain$0(CustomerContextSettingFilter.java:181)
... 3 filtered
at com.idalko.jira.plugins.igrid.servicedesk.ServletRequestContextFilter.doFilter(ServletRequestContextFilter.java:23)
... 3 filtered
at com.valiantys.jira.plugins.sql.service.servletcontext.ContextListenerServletFilter.doFilter(ContextListenerServletFilter.java:24)
... 5 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 19 filtered
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:37)
... 16 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 53 filtered
... 13 filtered
at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:56)
... 32 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:68)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:154)
... 19 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
... 2 filtered
at com.onresolve.jira.behaviours.restservice.BehavioursEndpoint.getValidatorsFromIssueId(BehavioursEndpoint.groovy:76)
at com.onresolve.jira.behaviours.BehaviourManagerImpl.runValidator(BehaviourManagerImpl.groovy:185)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:128)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:56)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:274)
at org.codehaus.groovy.runtime.dgm$163.invoke(Unknown Source)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:2151)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:2110)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:2125)
at groovy.lang.Closure.call(Closure.java:434)
at groovy.lang.Closure.call(Closure.java:418)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1034)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:264)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:325)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:98)
... 2 filtered
at com.onresolve.jira.behaviours.BehaviourManagerImpl$_runValidator_closure9.doCall(BehaviourManagerImpl.groovy:239)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:136)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:58)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:47)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoCachedMethodSite.invoke(PojoMetaMethodSite.java:192)
... 2 filtered
... 3 filtered
at Script1.run(Script1.groovy:8)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGetProperty(AbstractCallSite.java:299)
at org.codehaus.groovy.runtime.callsite.ClassMetaClassGetPropertySite.getProperty(ClassMetaClassGetPropertySite.java:50)
at groovy.lang.MetaClassImpl.getProperty(MetaClassImpl.java:3773)
at groovy.lang.MetaClassImpl.getProperty(MetaClassImpl.java:1828)
at groovy.lang.MetaClassImpl.getProperty(MetaClassImpl.java:1852)
at groovy.lang.MetaClassImpl.invokeStaticMissingProperty(MetaClassImpl.java:1014)
Possible solutions: jiraAuthenticationContext
groovy.lang.MissingPropertyException: No such property: JiraAuthenticationContext for class: com.atlassian.jira.component.ComponentAccessor
2022-07-28 16:33:09,430 http-nio-8080-exec-63 ERROR asastry_admin 993x53804325x1 6u87vr 172.21.22.242,192.168.0.33 /rest/scriptrunner/behaviours/latest/validators.json [c.o.jira.behaviours.BehaviourManagerImpl] Found class but could not find method run
 Thanks in advance,
Aditya Sastry
2 accepted
Florian Bonniec
Hi @Aditya Sastry
Does this script work better ?
def remoteUsersRoles = projectRoleManager.getProjectRoles(currentUser, issueContext.projectObject).collect{it.getName()}
def allowedResolutions = constantsManager.getResolutions().findAll { it.name != "Fixed"  }
Aditya Sastry
July 28, 2022
Thanks @Florian Bonniec for the neater version but I'd tried everything.
Florian Bonniec
@Aditya Sastry
Also currentUser line seems weird.
I personnaly use ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
instead ComponentAccessor.JiraAuthenticationContext.getLoggedInUser()
Aditya Sastry
July 28, 2022
After scratching my head for hours realized the mistake.
Incorrect line of code
Correct line of code
def currentUser = ComponentAccessor.jiraAuthenticationContext.getLoggedInUser()
