BigGantt installation problem
Кисляков Максим November 11, 2020
Hello Atlassian Team,
We are trying to install BigGantt (1.0.118-AC) on our Jira Software (Cloud) site, but after installation the BigGantt app does not work. I attach a screenshot. What could be the problem?
Thank you.
Sary Al-Assad November 16, 2020
I'm getting the exact same problem. Is this something new? and is It expected to be solved soon?
Кисляков Максим November 16, 2020
Hi Sary,
Yes, we solved the problem with the help of the vendor's support service. To do this, perform the following environment configuration.
Insufficient Jira Permissions guide
Maxim
Sary Al-Assad November 17, 2020
Thank you. I tried the permissions thing but the issue still exists. The problem described in the article (Biggantt needs access) is different from the one at the top of this thread (multiple "error" boxes).
Kindly let me know if there's another way to try and fix the issue.
Thank you
Mateusz Sołowianiuk
November 17, 2020
Hi @Sary Al-Assad
I am afraid that it will not be possible to provide you with an instant fix to this just on the basis of knowing your scenario. I invite you to raise a support ticket via our Service Desk so that we are able to investigate your specific case and advise how to resolve it.
Thank you in advance!
Best regards,
Mateusz Sołowianiuk
SoftwarePlant Support
Thank you Mateusz. For some reason biggantt is working now. Thanks again.
Mateusz Sołowianiuk
November 18, 2020
Hi @Sary Al-Assad
I firmly believe that the hotfix release that was deployed yesterday contained a fix to your issue. I'm glad that you're able to operate on the plugin without interference again.
Best regards,
Mateusz Sołowianiuk
Mateusz Sołowianiuk
November 13, 2020
Hi @Кисляков Максим
Thank you for opening the support ticket! I am sure that our team of experts will be able to resolve this in a timely manner. Hopefully, you will be able to benefit from BigPicture 8's features soon.
Best regards,
Mateusz Sołowianiuk
Alexander Pappert
November 12, 2020
are there errors in the logfile?
can a re-index help?
you could open a vendor ticket at marketplace https://marketplace.atlassian.com/apps/1213016/biggantt-gantt-chart-for-jira?hosting=cloud&tab=support
Кисляков Максим November 12, 2020
Where can I find the logfile?
As far as I know, reindexing is not currently supported by Jira (Cloud). Maybe I'm wrong.
Yes, I opened a ticket to the vendor, thank you.
