I am using Jira Software.
I want to prevent an issue transiting from 'create' to 'to do' if the following condition is met (in JQL). Can I achieve this without any marketplace plugins? If so, how please?
project = BPO
AND
created >= 2022-11-02
AND (
"Select one ticket type[Select List (cascading)]" in cascadeOption(10522, none) OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10532, none)
OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10623, none)
OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10325, none)
OR
"Select one ticket type[Select List (cascading)]" in cascadeOption(10176, none)
Hi @Cyan Lee
Out of the box following conditions are available.
Looking at your question I don't think you can achieve that without an app. You can use "User is in a Custom Field" and "Value Field" conditions to achieve some of your logic if not all.
Ravi
Another approach might be to use Jira Automation to set a flag in the labels field, and then check that flag in the workflow transition.
