Block to edit issues after determined step
nathalia_fukuda February 24, 2023
I need to block any user to edit an issue after opened. Today any user can edit an issue in any step that the issue is and it is a problem for the sprint. How can I do this?
Jack Brickey
Hi @nathalia_fukuda , which fields do you want to prevent editing and which do you you wish to allow? If you are using CMP projects then have a look at the Permission scheme under project settings.
I want to block the issue description only, after the creation of it. It is not a fied.
For exemple, I have this issue colled "Teste PMO" and it is in a step on the middle of the flow, but everybody can edit its description, even if the issue is already running.
The only moment I need it to be editable is when the issue is in the step of creationDesc.png
Jack Brickey
To be clear Description is a field. Regardless, you can't achieve your goal natively. You can look at add-ons if that is an option.
Like Kelly Arrey likes this
nathalia_fukuda February 28, 2023
Understood, thanks!! How should I do this with add-ons? It could be an option!
Jack Brickey
I have seen others use Scriptrunner' behaviors for this. Here is a post discussing this. https://community.atlassian.com/t5/user/viewprofilepage/user-id/5158965
