Board not visible in project with Process Management Workflow assigned
Przemek / Pshemek
Hi all,
I am quite new to Jira administration so please forgive my incompetence. I have assigned Process Management Workflow to my project (with all the Open/Cancelled/InProgress/Rejected/Under Review/Approved/Done states). But I cannot see the Board (the rectangle icon with three columns - please have a look below) which illustrates all the states - it is supposed to be on the left. How do I add it ?
Jack Brickey
Do you know that a board actually exists for the project in question? If not add a board and see if it then shows.
Przemek / Pshemek
The board does exist. Should it be Scrum or Kanban type board ?
Jack Brickey
So maybe the board is actually tied to your Profile and not the Project. Can you navigate to view all boards and have a look at what you see in the location? example below...
Przemek / Pshemek
I don't have location column ... :-(
Jack Brickey
are you on server or cloud? I'm on cloud so it may be different on server.
In any event let's check a couple other things:
  1. Let's check the project type. In view all projects what do you find in the Type column for the project?
  2. Check location via board settings. Go to the board settings and General and see what the Location is.
  3. If the board is in fact tied to your profile vs the project let's try changing the board's location w/in the General view.
something to note, if your project is a Business type the board you create cannot be associated to the project but only your profile. At least this is the case in Cloud.
Przemek / Pshemek
This Jira instance is installed on cloud based VM (so is it on server or cloud ? ;-) ).
1. Project type: Business
2. There is no 'Location' in the Board settings (in General)
You are saying that because this is Business project it cannot be associated to the project. But when I go for Create Board it is asking me if I want to create an Agile board from an existing project (please have a look at the picture).Screen Shot 2018-01-09 at 14.49.50.png
Jack Brickey
so in General you do not see something like below?
Regardless, let me backup and try to clarify a few things and then rewind to your initial problem.
  • When you create a new project it should create a default board which is viewable on the main project page (the three column icon you mentioned earlier). This default board is very limited and you cannot access the settings and modify like other boards you create. Now I have seen a scenario myself where no default board did exist but not clear why this occurred.
  • If you create a board then it's Location is dependent upon the project type. If Software you can set the location to the project and it will show in the project under the three column icon. If the project is of type Business then it cannot have the location be the project itself but you can save into your Profile by selecting your name. In the screen shot you provided if you continue down the path of setting up the board you will see this in the next screen. Please try it to observe Location field as the last selection. If you click on the drop down you will see a list of Projects and My Profile. If the project is not listed then it is not a Software project and therefore cannot be selected so you have to associate to your profile. The only downside is that you won't be able to access via project screen.
Jack Brickey
Now, I'm thinking that you are on server and that this thread may actually be related to your issue but unsure. You indicated your instance is hosted in the cloud but if self-hosted then it is server. Atlassian's Cloud instances will have a url something like company.atlassian.net.
Przemek / Pshemek
In 'General' I don't see anything like 'Location' ?
Also when creating a new board there is NO Location settings at all.
Jack Brickey
ok then for sure you are on server. I'm unsure how the board should appear (icon) in server. Do you see the icon on some projects but not others?
Przemek / Pshemek
This is fresh installation and that was the first ever project created on this server.
Jack Brickey
so what leads you to believe the icon should be present? Is that in the documentation? If so can you point me to it?
Przemek / Pshemek
We have hosted jira server (atlassian.com) as well (the main one) where the icon does exist. And after creating the new one it was natural to look for the same feature. I wasn't aware that the server version doesn't have the hosted jira features (as in the link you mentioned).
Jack Brickey
aha...that explains it. I certainly understand where you would conclude this. However, as this lengthy :-) exchange has shown Server and Cloud look, feel and act quite differently. The icon is what initially thru me off and why I was assuming cloud. I should have gotten to the bottom of this sooner simply by answering the cloud/server question. Oh well, it was fun anyway. ;-)
