Body for Checkbox set value in Jira Rest API with POST in Scriptrunner is not valid object
Fawaz Joseph October 27, 2023
So I'm trying to set checkbox values using script runner specifically Script Listener.
This is the code I'm trying to execute
 put("/rest/api/2/issue/${issueKey}")
.header('Content-Type', 'application/json')
.body([
fields: [
"customfield_10036": [
[["value": "ALL"], ["value": "BT7"], ["value": "MACS"], ["value": "SPINS"], ["value": "BT4"], ["value": "NGB30"], ["value": "NG7S"]]
]).asString()
However for some reason, I get this error
body: {"errorMessages":[],"errors":{"Instrument":"The Instrument value must be an object"}}
How the value not an object.
Thank you
4 votes
Kristian Walker (Adaptavist)
Hi Fawaz,
I can confirm we have an example script that can be run  on the script console that shows how to set a checkbox field here.
You will be able to use this script to help write the rest API call neeed to set the checkbox values via a script listener.
I hope this helps.
Kristian
Bobby Bailey
October 27, 2023
Just to add, the only issue with your call @Fawaz Joseph is you have 1 too many sets of brackets,
[["value": "ALL"] <- all your other options -> ["value": "NG7S"]]
Should become:
Thank you @Bobby Bailey
This fixed my problem
Thank you for the snippet @Kristian Walker (Adaptavist)
This will be very useful going foward
Hi Fawaz,
You are welcome, and I am glad we managed to help you to achieve your requirement.
Kristian
FREE
