CONDITIONS FOR WORKFLOW STEPS USING GROOVY SCRIPT
Camelia September 18, 2017
import java.sql.Timestamp
if (issue.getIssueType().getId() == "193") {
   if (issue.getWorkflowId == "<to check the workflow step id... what to insert here? and where to get it?>") {
      issue.setDueDate(new Timestamp((issue.dueDate + 3).time)) // set due date
      issue.setDueDate(new Timestamp((issue.dueDate + 7).time)) // set due date
This groovy script will check for conditions by the workflow step id. How can I do so? Can anyone show me the code? Urgent. Need help ASAP. Thanks in advance.
Nic Brough -Adaptavist-
September 19, 2017
That's going to be hard work if I remember the API correctly.
Why don't you just use two scripts, one on each post-function?
Camelia September 19, 2017
I thought of making it all in one script because I might need to add more codes for different days for each workflow steps.
If there's like 10 set of different days, that would be 10 scripts.
Which one is the best solution for this matter? If the one with conditions is the best, if you don't mind show me a sample of the code.
What would you suggest, Sir?
Thank you.
Cam.
September 20, 2017
Ok, if you use the id's, you'll need some (potentially unpleasant) code to find them.
I'd take a different route.  If you wrote 10 scripts and saved them as files in the scripts directory, you could use them repeatedly without thinking about transtion ids.  You'd say "use script add-4-days for this transition" and for the next one "use script add-6-days", and for a third, reuse add-4-days.  It'll keep your scripts very short and simple.
Another option is a bit longer - you could use a single script that reads a transition property that you add to transitions, which is a lot easier to get to in a post-function than the id.  Also means one script keeps it really simple!
Camelia September 20, 2017
Hi Sir,
Oh, I see. And if I may ask, could you provide and show me the code for it?
As I'm not really familiar with it.
I appreciate if you could lend me a hand.
Thank you.
Cam.
