Calendar View not showing Issues
Omar Osman August 14, 2024
Hello, I'm really excited about the new calendar view for Jira Software. I've created some issues and assigned start and end dates for a Kanban board. However, I'm not seeing those issues on the calendar view. I'm not sure why the start and end dates are not syncing with the calendar view. I tried dragging the issue to the calendar using the unassigned button and then I tried dragging the dates for the issue. However, the dates didn't update on the issue. I repeated the process and it seems the issues are not fully synced with the calendar. I'm not sure how to fix this.
Samuel Gatica _ServiceRocket_
Hi @Omar Osman
Welcome to the community!
"Only tasks with due dates are shown in your calendar."
Ref: https://support.atlassian.com/jira-work-management/docs/what-is-the-calendar-view/
Please ensure that you set the Start date and Due date in your issue to enable visibility on the Calendar.
Hope this helps!
Best regards
Sam
Omar Osman August 15, 2024
Hello Sam, could you please share the steps to make the Start and Due dates visible on the Calendar?
Currently, I do have Start and Due dates enabled for Issue.  For some reason, they are not synced with the Calendar.
This issue I had to manually add to the calendar after creating it. The start date seems to sync however the End date is not syncing.
Hi @Omar Osman
Please be sure to include the "Due Date" field on the screen, as the calendar will rely on this date as the end date.
Best regards
Sam
Omar Osman August 16, 2024
I have another ticket which I have created and entered the Start Date. However, it does not appear on the calendar. image.pngimage.png
matthew.burke@pgn.com
October 15, 2024
Omar you must have a due date to show I've found.
