Can I add a column for linked issues in Structure?
Vee
June 23, 2022
I am trying to add a "Linked Issues" column to my structure and noticed that it's not available. This was available for structure on-prem. Is there a way I can add it with a formula column instead?
David Niro
Hello @Vee ,
David from ALM Works here.  Welcome to the Community!
At the moment, this is not possible.  We are still driving towards parity between the on-prem and cloud versions of Structure and have a task related to this.
I have added your vote to the task and will follow-up with you here when there is an update to share.
Best Regards,
David
Vee
June 23, 2022
That's too bad but I appreciate the update. Thanks David!
Like Dave Rosenlund _Trundl_ likes this
Stepan Kholodov _Tempo_
Hello @Vee
It is now possible to see linked issues in the Formula column using the issueLinks function.
Please reach out to us directly at our support portal if you need any assistance.
Best regards,
Stepan Kholodov
Tempo
