Can I bulk copy issues within or to a project?
Alison Ha
July 17, 2013
Hi
Is there any way to bulk create instances of a group of issues and be able to change the issue type in the same process?
I know there is a bulk change feature which allows you to move issues to a new project or change the issue type which is no use to me because I want to keep the existing issue.
If anyone can help thanks!
Onkar Ahire
July 17, 2013
Hi Alison,
As I understand copy project in scriptrunner plugin is helpful for you, once you done it then make a bulk change for issue types in newly copied project, then move issue to the previous so you can keep old issues and newly created issues also with different issue types.
Regards
Onkar Ahire
Dnyaneshwar Ramesh Borase
Hello Team,
We are using JIRA v7.10.2 server version. Then how can I do bulk copy issues within or to a project.
Is there any plugin is available then please let us know.
Thanks!
