×I want to create rules based on issue type in order to segregate them into different boards. for e.g. stories will be reflected in one kanban board
bugs will be visible in another board.
You don't need to create automation rules for this. I assume that you are working on CMP. This means that every kanban board is created based on a filter. The only thing you've got to do is to create separate JQL filter which will reflect your business requirements. E.g.:
Now head over to one of your boards:
Let me know if you got this!
@467_SHRUTIKA SHELKE kindly mark my answer as accepted, in order to help others with similar questions. Much appreaciated!
