Each of our JIRA (version 3.13) projects has a number of custom fields which only apply at Project level (i.e. the Project Manager, Project start/end date, Budget ID etc.).
Currently (as I inherited things) each project has a custom issue-type called "Project Info" with all of these fields defined as custom fields. Then for each project we just create an issue of this type (conventionally the first issue number, e.g. ABCD-1 for project ABCD).
This is clearly a kludge.
Is it possible to define custom fields like this which are only visible at project level? It does not seem to be, but maybe I missed something.
A related isssue is what is the 'Project Information' panel (a documentation link would be nice). For my test project I am told "The 'Project Information' panel is not available."
No. See and vote on https://jira.atlassian.com/browse/JRA-1991 - some neat suggestions, workarounds and related links are there too, so it's well worth a read.
There is an add-on in the market that cover exactly the need you have: Profields - Custom Fields for Projects
https://marketplace.atlassian.com/plugins/com.deiser.jira.profields/
With Profields you can:
Cheers, David
How is the API coming David?
Coming soon
We are doing the final adjustments to have the best API ever. The documentation will be published the week of 29 Sep 2017
Hi @Brian W. Bishop, sorry for the delay, finally the Profields' version 5.2.0 contains a Java API. You can find the documentation about it here: http://profields.javadoc.deiser.com/5.2.0/
David
Thank you David! Will probably use your plugin in some capacity, if we can reach the field values from groovy. I want to dynamically change workflows/transitions based on project-level specifications.
There are few options, unfortunately not for your (old) Jira version:
You could check the "Jira Workflow Toolbox" plugin (but available for JIRA 3.2 to JIRA 4.3.4):
Quote from plugin-page: " - Check project property: uses the project "Description" to store properties that can be used to customize the workflow behaviour. Project properties are written in project description with this syntax: { property_name = property_value }"
Another option: "Custom Project Properties for JIRA"-Plugin (JIRA 4.0 to JIRA 4.2.4)
Excerpt from doc:
"Now we can:
=> You might want to consider updating Jira? ;-)
BR, Markus
I have embedded a project property and now I am trying to access it via SIL:
string thisProject = project;
JProject thisProjectProperties = admProjectProperties(thisProject);
string libraryProject = thisProjectProperties["library"];
which results in an error:
Structure JProject does not contain field library
{library=BDFLIB} is the Description of the project in question...
Any ideas? Also tried hardcoding the current issue's project key like so
JProject thisProjectProperties = admProjectProperties("BLAH");
