Hi @Sunil Kumar
Welcome to the community.
There is "Run a script" function in automation which may help you.
Hi Akdeniz,
I saw the option but getting an error no plugin available and shows deprecated for us.
Any idea why?
Sunil
I have seen the ScriptRunner option not load after updating both plugins. Atlassian's official suggest to me was to disable and re-enable ScriptRunner and that does seem to work.
Hi Sarah,
The option seems to be working as expected now. Thank you for the solution.
Sunil
Hi @Sunil Kumar
It's a no code automation feature
May I know what feature you looking to achieve, may be we can look if it achieved through available trigger, condition, and actions
Hi Pramodh,
Thank you for the wishes,
I am trying to execute a script every 15mins in JIRA. Is that possible without using jobs functionality in script runner as there is bug.
Sunil
Yes! There's a "Scheduled" trigger option, and you can click on a link that says, "use cron expression" and it will display as follows:
Hi Sarah,
But I want to add a script after the scheduling option which is deprecated right now.
Sunil
