Can issue keys in a project be resequenced
Ward Schwillens_ Schwillie
Can issue keys in a project be resequenced so that the lowest key starts with -1 again, and then sequentially the rest of the keys are renumbered too?
Nic Brough -Adaptavist-
January 5, 2024
Yes, but you're going to be very very bored for a very long time while doing it.
  • Move all the issues into another project with bulk-edit.
  • Create a new project.
  • One by one, move each issue from the temporary holding project into the new one, in the order you want.
I think it might be a better question to ask why you want to do this?  What would you gain from re-sequencing a pile of unique ids (other than satisfying some people's OCD-like tendencies)
Hi Nic, indeed you are right about the OCD-like tendencies! 😁
Thank you for the suggested work around.
3 votes
Fazila Ashraf
Hi @Ward Schwillens_ Schwillie
Unfortunately not.
In case you need to skip the initial numbers in the sequence, that is possible though - https://confluence.atlassian.com/jirakb/how-to-set-the-starting-issue-number-for-a-project-318669643.html
Hi Fazila, thank you for your insights!
Like Fazila Ashraf likes this
Nikola Perisic
Hi @Ward Schwillens_ Schwillie ,
Issue keys in Jira cannot be changed. Since this needs to be in the ascending order, you should be using a JQL query for this instead.
BR,
Nikola
Thank you for your insight Nikola!
