Can not use Forge bridge invoke in Connect on Forge app.
Hieu Nguyen
January 20, 2025
I'm developing a Connect on Forge app for Jira Cloud. I imported the invoke function from @Forge/bridge to use in the code file of connect modules in the remotes/connect folder to call to forge modules and got the error Uncaught BridgeAPIError: Unable to establish a connection with the Custom UI bridge.
Do you have any idea of what problem could be?
Tuncay Senturk
Hi @Hieu Nguyen
There may be several root causes for this error. Did you try forge tunnel? Do you get a similar connection error when you use tunnel?
As the error states, Forge apps do not work directly without being embedded in the Atlassian context. However, I trust you have already configured the Bitbucket connection correctly in your manifest file, and it has been well configured.
@forge/bridge can only be used in Custom UI components, It does not work outside a Custom UI context, I mean for backend or resolver calls, you can use @forge/api instead of bridge.
Last, I'd strongly suggest posting these kinds of developer questions on the Atlassian Developer Community, as you can receive more answers.
Hieu Nguyen
January 20, 2025
@Tuncay Senturk Thank you so much!
FREE
