Hi there,
I have created components for my project but now can't add the "components" field to the issue context fields nor can I add it to the default fields for when we create new issues.
Is this an admin setting? Where should I look for for this option?
Thanks!
Hi @Elissa Fontaine and welcome to the community!
You have to add fields to screens. To do that in your project, and assuming that you are in a CMP, then:
Hope that helps!
Hi @Alex Koxaras -Relational- thanks for the quick reply! I assume you need to have admin rights to do so, correct?
Thanks! Elissa
You are most welcome! Kindly mark this answer as accepted, in order to help other in the community! Thank you! :)
