Can't add project settings page on Business project
An Nguyen March 9, 2022
I tried to add a project settings page for my addon. It success for company and team-managed project but i can't add to business project. Doesn't it support for business project ?
carlosughini
Hi @An Nguyen ,
Welcome to the community!
It is important to note that when creating a Work Management (business) project, you can still choose between company or team managed project.
Also, different from the software projects, the menu for managing the apps is different. You can still see the options directly in the left menu and not in the project settings option:
However, it is important to note that not all apps that you have will have functionalities for the work managements projects.
Could you please provide us an image and more information about what exactly are you missing?
Carlos
@carlosughini
Thanks for your reply. I want to do like below
I added module jiraProjectAdminTabPanels  in connect.json file but it doesn't work for Business Project
Luris Higuera
May 4, 2022
it seems that project pages are not enabled directly to jira... so you would have to switch back and forth
