Can't connect JIRA and Confluence Project
Community_Hub January 14, 2020
I've tried to connect my JIRA project with a confluence project, but it's not working and I don't know why.
All I see is "Connection failed" and I'm not sure why.
My JIRA dn Confluence instance work. I'm able to access both with the same client session/browser session.
Did anybody else experience this? Any ideas how to resolve this?
Mike Bowen
January 14, 2020
Okay @Community_Hub , Try it in reverse by doing the following:
  1. Go to your Confluence space, and on the sidebar, click Space settings > Integrations.
  2. Click the Application Links tab.
  3. Click Add Link, System JIRA (JIRA).
  4. Enter the space key or space name, then click Create.
  5. Now go back to your Next-Gen project and connecting to the Confluence Space.
-Mike
Thanks, that didn't work as expected;)
I've run into an error here ( No Perm Error) , which I guess was also the reason for the issue.
Once the error was resolved by clicking on "Administration"
it worked as expected.
BTW regarding your step 3, the JIRA link was already there.
Thanks for the heads up.
Mike Bowen
January 14, 2020
Hi @Community_Hub
How are you getting to the step that produced the screenshot? If you could describe the steps that would be useful. Also is your project a classic or Next Gen project?
Also worth confirming under Project Settings - Features (assuming a Next-gen project is in play), Do you have Pages turned on? (Create, share and collaborate on all your project docs in one place. Requires Confluence by Atlassian).
-Mike
My Project is a next gen project.
Inside the jira project I've clicked on "Pages" and "Connect a Space". This will open the above form, where I've tried to select the existing project and which then  results in the error.
The connection works def. because I'm able to create a new confluence project from the form, only connecting to an existing project fails unfortunately
Gustavo Gassmann
April 13, 2022
That is happening to me too, but my project isn't a Next Gen. It isn't my first project linked with confluence, but It is the first I try to link after create a space on confluence.
I went to confluence and add Jira project as a link integration and made too on Jira, but both don't solved the issue.
Do you know other options to try?
