Can't create an issue anymore with jira-rest-java-client-core
Victor Mosin July 17, 2019
I've been using those library for a year and it was fine. Approx. 1 or 2 weeks ago it stoped to work.
POM
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-rest-java-client-core</artifactId>
<version>5.1.2-2bd0a62e</version>
</dependency>
<dependency>
<groupId>io.atlassian.fugue</groupId>
<artifactId>fugue</artifactId>
<version>4.7.2</version>
<scope>provided</scope>
</dependency>
Java
BasicIssue task = jiraRestClient.getIssueClient().createIssue(taskBuilder.build()).claim();
Server respond with
com.atlassian.jira.rest.client.api.RestClientException: org.codehaus.jettison.json.JSONException: A JSONObject text must begin with '{' at character 10 of
<html>
<head>
<title>Unauthorized (401)</title>
<!--[if IE]><![endif]-->
<script type="text/javascript" >
var contextPath = '';
var DeferScripts = { deferState: 'disabled' };
</script>
<script>
com.atlassian.jira.rest.client.internal.async.DelegatingPromise.claim(DelegatingPromise.java:45) ~[jira-rest-java-client-core-5.1.2-2bd0a62e.jar:na]
at com.smoope.utils.testcasegenerator.TestCaseGeneratorApplication.run(TestCaseGeneratorApplication.java:77) [classes/:na]
at org.springframework.boot.SpringApplication.callRunner(SpringApplication.java:790) [spring-boot-2.0.0.RELEASE.jar:2.0.0.RELEASE]
at org.springframework.boot.SpringApplication.callRunners(SpringApplication.java:774) [spring-boot-2.0.0.RELEASE.jar:2.0.0.RELEASE]
at org.springframework.boot.SpringApplication.run(SpringApplication.java:335) [spring-boot-2.0.0.RELEASE.jar:2.0.0.RELEASE]
at org.springframework.boot.SpringApplication.run(SpringApplication.java:1246) [spring-boot-2.0.0.RELEASE.jar:2.0.0.RELEASE]
at org.springframework.boot.SpringApplication.run(SpringApplication.java:1234) [spring-boot-2.0.0.RELEASE.jar:2.0.0.RELEASE]
at TestCaseGeneratorApplication.main(TestCaseGeneratorApplication.java:46) [classes/:na]
Caused by: com.atlassian.jira.rest.client.api.RestClientException: org.codehaus.jettison.json.JSONException: A JSONObject text must begin with '{' at character 10 of
Aleksandr Zuevich
July 18, 2019
Hi Victor,
Basic authentication with passwords and cookie-based authentication are now deprecated and disabled.
"The deprecation period for this functionality has ended. From June 3rd, 2019, we will be progressively disabling the usage of this authentication method" - https://developer.atlassian.com/cloud/jira/platform/deprecation-notice-basic-auth-and-cookie-based-auth/
You can use Basic Authentication with tokens instead of credentials.
Ben
April 22, 2020
So what java library should we use instead?  I suppose we need to write our own `AuthenticationHandler` to implement the new way of doing things.
Aleksandr Zuevich
April 23, 2020
Hi Ben,
It seems you just need to use API token instead of password.
gianluca-valentini
April 6, 2022
I used the API Token too but I have the same error. Using jira-rest-java-client-core v 5.2.4
Is there something that I can do to solve it?
private JiraRestClient getJiraRestClient() {
BasicHttpAuthenticationHandler authenticationHandler = new BasicHttpAuthenticationHandler(this.username, this.password);
return new AsynchronousJiraRestClientFactory().createWithAuthenticationHandler(getJiraUri(), authenticationHandler);
private URI getJiraUri() {
return URI.create(this.jiraUrl);
where I use the api-token instead of the password. But It does not work
Ben
April 22, 2020
