Can't see more than 6 issues at Done column in a kanban board in Jira. Any ideas why?
Vasilis Gen May 17, 2023
As described in the title for some reason I can only see only 6 issues in the Done Column on my company managed kanban board. Every other issue I move to the Done column it disappears. Any idea why that happens?
JM Perrot
Hello @Vasilis Gen
One possibility can be your kanban filter/subfilter. (Directly in the board settings)
Can you check them ?
Another option is your mapping of your columns, you can check that in board settings -> columns
Vasilis Gen May 31, 2023
Thanks for the answer! Finally was an issue that we had with Resolution field..
