Hi, I have "Özet" system field and it is being used in some projects as mandatory field. Now I want to set it unrequired but in field configuration, there are no option to do that. I see only "arrange" and "screens" on the right side. Any idea?
Gerekli=required
Düzenle=arrange
Ekranlar=screens
This field is alwails required and it can not be canceled.
Labels, description, security level, duedate, resolution, resolutions date, component, fix versions are also system fields an are not requared by defaul.
Issue type, project, author are also system field and always requared.
So, this is a build-in feature of JIRA.
This question has been discussed: https://community.atlassian.com/t5/Jira-questions/Summary-field-not-required/qaq-p/319781
