Can use REST Jira calls in browser, not in C# program
khooker
May 21, 2019
Hi all,
    I can log into my Jira cloud account with my username and password via chrome and then enter a Rest call on the address bar like this:
https://xyzonline.atlassian.net/rest/api/2/issue/10011
..and it returns the expected json issue object to my browser.   But an HttpWebResponse call in a C# program using the same credentials gets a 404 every time (method is a GET):
HttpWebRequest request = (HttpWebRequest)WebRequest.Create("https://xyzonline.atlassian.net/rest/api/2/issue/10011");
request.Credentials = new NetworkCredential("me@xyzonline.com""MyPass");
request.Method = httpMethod.ToString();
HttpWebResponse response = (HttpWebResponse)request.GetResponse();
...Same computer, seconds apart. Anyone see what I'm doing wrong?
Alexey Matveev
May 21, 2019
You need to generate API token instead of the password:
https://confluence.atlassian.com/cloud/api-tokens-938839638.html
khooker
May 22, 2019
Hi Alexey,
    I've tried that and it failed also but perhaps I have the syntax wrong.  Does anyone have the syntax for using the API-generated key in a simple C# / .Net example?
