Integration aspect I am looking are as follows;
1) Can we generate MS-Project from the JIRA tasks from a project. Or can we generate JIRA tasks from MS-Project by project
2) How we can update MS-Project with the changes happening in JIRA at tasks level by daily or weekly
3) Please suggest if possible then do we have auto / semi auto functions available
Regards
Not without a 3-rd party plug-in. Check out Ceptah Bridge: https://www.ceptah.com/. It can perform the task you described.
This doesn't work on ios
Yes, the only way to run it on Mac is to run Windows using Boot Camp, in Parallels or on a VM. Windows seems to be free for Mac installations.
And MS Project Pro is included in Project Plan 3 and 5
Take a look at the apps listed on the market place at https://marketplace.atlassian.com/search?q=%22microsoft+project%22&application=jira - there are some options there, all different.
Alternatively, you should look at Jira Advanced Roadmaps (formerly known as Jira Portfolio): https://community.atlassian.com/t5/Jira-articles/Introducing-Advanced-Roadmaps/ba-p/1378497
