Can we create a issue in another project by ticking a check box
Teja February 27, 2024
Hi ,
I'm looking for a functionality when check box is ticked it should automatically create a ticket in that specific project.
Example:
I have a master project in which a ticket is created . In this ticket I want to show a check box containing keys tasks to be done to fulfil this ticket.
For example, lets take Change Request Ticket, here I want to display options of checklist.  Here in this check list which are individual projects.
check box
Detailed Design
Test & Verification
Stock Control
These are project which will be shown in check box by ticking these check box a ticket should be create with specific issue type
Tansu Akdeniz
Hi @Teja
If you have Automation for Jira, create an automation rule from Project Settings -> Automation.
  • When Checkbox field is changed (value added)
  • If checkbox contains any value of xxx
  • Create issue
Hi @Tansu Akdeniz
Yes, I tried this automation and it created tickets. But this is displayed as a dropdown list .
check box = dropdown
It should show the status and create a ticket when it checked.
