Can we disable linking issues to an Issue when it is closed
Vishnukumar Vasudevan
Hi All
Is there a way to restrict linking issues to a closed issue ?
Thanks, Vishnu
6 votes
Jobin Kuruvilla [Adaptavist]
February 1, 2012
Can you try removing the permission using worklofw properties?
http://www.j-tricks.com/1/post/2011/02/permissions-based-on-workflow-status.html
Haven't tried that for linking but it surely works for some other permissions. Worth a shot.
Jobin
Thanks for the link. It's similar to http://confluence.atlassian.com/display/JIRA044/Workflow+Properties
But I don't see any properties for restricting Issue Links.
February 1, 2012
You don't restrict the property. You restrict the permission as mentioned in the above post. Something like:
jira.permission.link=denied
If that doesn't work, try:
jira.permission.link.group.1=some-group-one
where some-group-one is a group that aready had linking permission but doesn't have any users in it or has only limited users like admins.
As I said before, I haven't tried this purticular example but it should work.
Like Walter Lamm likes this
Thank you so much Jobin.
The second one works well.
Stephen Chai
November 30, 2013
Hi, I tried to disable linking but it only works when I want to disable Issue A (closed issue) from linking to issue B. It doesn't prevent me from linking Issue B to Issue A. My aim is to prevent any blocking issue to Issue A as long as it is closed, as this breaks the workflow I have set up. Any help will be greatly appreciated. I'm new to Atlassian and am now trying to learn how to configure it for our workflows.
Ilya Turov
October 29, 2019
kinda late to the party, but just adding
jira.permission.link.denied with empty value
to status properties seems to work
Like # people like this
Olaf Troike
June 5, 2020
I add the property to the closed status, but it doesn't work. It only works when I want to disable Issue A (closed issue) from linking to issue B. It doesn't prevent me from linking Issue B to Issue A
Сергей
July 23, 2020
Dear Olaf,
Did you found the resolution for this request?
Jonathan Smith October 14, 2020
@Olaf TroikeI have the exact same question as you - did you ever figure out how to lock linking issue B to issue A?
jira-admin_telenor February 3, 2021
@Olaf Troike @Jonathan Smith dod you guys find out how to restrict issue B from adding a link to issue A where the  jira.permission.link.denied is in place for issue A
Jonathan Smith February 3, 2021
I have not found a solution.
Like jira-admin_telenor likes this
André Stuhrmann June 8, 2021
I did not know which one would be the correct property, so I have tried
jira.permission.link with denied in the right column
jira.permission.link.denied - as suggested by @Ilya Turov
None those would work. Any help?
André
Tomas Slavkovsky
This works:
The answer is here.
Like Devo likes this
Nic Brough -Adaptavist-
February 1, 2012
No, there's no way to do this.
If you wanted, you could investigate amending the core linking code to add such a check, but that's a lot of work (and I'm not sure the requirement is actually that useful - how do you link to duplicates or refer back to useful tickets?)
My requirement is, just wanted to make sure that No one links any CR's to a Release which is already closed.
Katarina Nikolic June 23, 2017
Dear Vishnukumar,
Thank you.
Katarina
