So, I have 2 different projects, let's say project A and project B, i have put the issue in fix version in project A, and in project B i create custom fields short text, to put the name of the fix version, and i want to validate from the custom fields in project B, is the name of the fix version exist in project A or not, is it possible to do that?
unfortunately, from Jira Conditions and Validators, you can only use Atlassian's Jira Expressions language, which doesn't provide access to the list of existing Versions ("releases") in a project. So you won't be able to do what you're trying to do.
Hi @Nicolas Andika,
You can use new Issue(ISSUE_KEY) to load an issue with the given key and then get the field values of this issue, for example:
let otherIssue = new Issue("JMWE-1");
otherIssue.fixVersions
In the above example, I'm retrieving the issue with key JMWE-1 and then retrieving its Fix Versions in line #2.
So, if you want to check that the value of the short text field of current issue exists in the Fix Versions of another issue -> you can use the below Jira Expression:
!issue.customfield_10900 || otherIssue.fixVersions.some(it => (it.name == issue.customfield_10900))
You need to replace
I hope this helps!
BTW, I'm from Appfire, the vendor of JMWE app. A support ticket has been created in our support portal for this case: SUPPORT-165870. However, we couldn't add you as a reporter. We’d like you to sign up for our support portal here and let us know your username so that we can mark your ID as the reporter and you will be able to access the ticket.
If the above solution doesn't work for you or your requirement is different, please feel free to share it on the support ticket.
Suprija | Appfire
Hi, thanks for the advice,
but i still have a question, is it possible to not only targeting the specific issue, i want to check all the issue if it matches that will return true, but if all the issue doesn't match, it will return false?
Nico
My Name in Appfire Website is Nicolas Andika Tjandra
What do you mean by "check all the issues"?
If you're trying to force the user to enter a Version that's a valid version on project A, then see my answer above.
However, you mentioned that you selected a specific Fix Version in an issue of project A, what's the relationship between that issue in project A and the issue in project B?
Can you describe in more details what you're trying to achieve?
In project B I create custom fields name "Release" in a short text type, and then i want to create validators inside the workflows using the JMWE with build own script to check is the value of the "Release" Custom fields in project B is an exist fix version in Project A
Right. So my first answer (at the top) stands: this is not possible on Jira Cloud, unless you create your own App using Forge.
Hi @Nicolas Andika - the answer added by @David Fischer is correct. Jira Cloud workflow Conditions and Validators can only be written using Atlassian's Jira Expressions, and this doesn't allow you to access the list of versions ("releases") in a project.
Suprija
