Can we write an automation to edit an issue field in one project when the status of an issue in another project transitions?
I have 2 projects A and B.
When the status of an issue in A changes to Completed, I need to copy the value from custom filed Version in that project to project B.
Hi @Anjana V K
yes, you can.
first, start by using the trigger as issue transitioned and select the relevant statuses you are after.
then add a condition from type "issue field condition" and select project field and then select value as project A.
then create a variable and assign to it the value of custom field suing smart values.
last you can assign the variable value to any ticket you want in project B based on branch using JQL query
hope the above helps.
Hi @Anjana V K
Yes, that can be done. The rule will need to a have multiple-project or global scope to work on both projects. Such rules are created from the global rules area; as you appear to be a site admin, you should be able to do that.
