Hey all,
Is it possible to create an overdue smart filter when a fix version has passed it's release date?
I am using Jira Server.
Thanks all!
Can I clarify what you mean by smart filter? Do you mean create an issue search based on a release being overdue?
If you're looking to do an issue search, it's not native functionality - you'd need an App which allows for more advanced JQL functions, like Scriptrunner
Then for example - to see all Issues in an overdue version, that aren't closed, you might use...
fixVersion in overdue() and status != Done
Ste
Hi again @Ste Wright
Sorry, that's right, I wanted to create a smart filter based on an issue search when a release is overdue.
Thank you for letting me know, I will look into Scriptrunner.
Thanks for assisting me with both of my questions :)
No worries!
Let us know if the above meets your needs, after looking into Scriptrunner :)
Ste
